Adjustment - Characteristics
You use this page to link additional information to the adjustment. Open using Menu > Financial > Adjustment > Search and navigate to the Characteristics page.
Description of Page
The characteristics collection contains information that describes miscellaneous information about the adjustment.
Characteristic Types. You can only choose characteristic types defined on the adjustment's adjustment type.
The following fields display:
Characteristic Type Indicate the type of characteristic.
Characteristic Value Indicate the value of the characteristic.
Default Note. An adjustment's characteristics default from the adjustment type.
