Interval Value
Each piece of interval data for the same bill factor/characteristic will be stored as an Interval Value record linked to the newly created data set. The name of this table is CI_​INTV_​VAL. The following table describes each column on this table.
Column Name
Length
Req'd
Data Type
Comments
INTV_​VAL_​SET_​ID
12
Y
A/N
This is a foreign key reference to the Interval Value Set that groups the interval values together. This should be your newly created id from above.
INTV_​VAL_​DTTM
26
Y
DateTime
This is the date and time of the interval value. This must be stored relative to the base time zone. Refer to Time Zone and Time Changes for more information.
INTV_​VAL
18.7
Y
N
This is the value (price) for the interval.
