Rate Check Results - Register Read
After you have pressed the Check Rate button on the Main page, you can navigate to the Register Read tab to view the final quantities (Final UOM, Final TOU and Final SQI) that were derived by your rate's register rules.
Description of Page
The Rate Schedule and its description, the Revenue Class and its description and the Bill Period are displayed at the top.
This page displays measured quantities from one of two places:
  • From the values input on the main page of Rate Check
  • From the Register Read collection for the bill segment indicated on the main page of Rate Check
The final quantities will reflect any changes to the measured quantities resulting from applied register rules.
The following information is displayed in the grid:
  • UOM is the unit of measure of the measured quantity.
  • TOU is the time-of-use code of the measured quantity.
  • SQI is the service quantity identifier of the measured quantity.
  • Measured Quantity is the initial quantity amassed by the system before application of the rate's register rules.
  • Final UOM is the unit of measure of the resultant billing quantity.
  • Final TOU is the time-of-use code of the resultant billing quantity.
  • Final SQI is the service quantity identifier of the resultant billing quantity.
  • Register Quantity is the resultant billing quantity.
  • Service Point ID displays information about the service point used by rate check to determine any characteristic values needed for the register rules.
