Simple Summary
Simple Summary calculation rules create a "subtotal" on the bill by summarizing bill lines produced by other calculation rules in the same calculation group.
- Rule Name: Simple Summary
- Base Package Calculation Rule Business Object: C1-SimpleSummary
- Apply Calculation Rule Algorithm Type / Algorithm: C1-SIMP-SUMM
Rule Parameters:     - Referenced Calculation Rules: Defines the calculation rules that should be included in the summary. Note that any calculation rules listed here must belong to the same calculation group as the Summary rule.
Example: This calculation rule creates a summary of
TOU-based charges (based on rules within the same calculation group
as this rule). 			Calculation Group: Commercial TOU Electric Charges Calculation Rule: KWHTOT Sequence: 40 Description: Consumption Subtotal Description On Bill: Consumption Subtotal Print: Yes Print if Zero: No Rounding Type: Nearest Precision: 0.01 FCPO: No Referenced Calculation Rules: - Off Peak - kWh
- On Peak - kWh
- Shoulder Peak - kWh 			Cross Reference:
- Member Category (Category Type / Value): Taxable / State Tax
