Switch Language Zone
The Switch Language zone is used to switch the application's language. Only languages that are supported by your implementation will appear.
To switch the application's language, choose the desired language and press the Refresh button.
Note: If your implementation uses a single language, you should suppress
this zone by  not granting security rights to the zone's application service.
