Explorer Zones
The product provide several zone types that are used to find or display a set of information. These are called explorer zones. There are two types of explorer zones:
Info zones. An info zone displays a list of information about an object. These types of zones often display information without requiring any input from the user.
Query zones. A query zone allows users to find objects matching a given search criteria.
Virtually every aspect of an info or query zone is controlled by its zone configuration. However, most share basic common components described in the subsequent sections.
