Load Data Batch Run Parameters
The data upload batch is processing single target object – Table or Maintenance Object. The data extract may be supplied in one or multiple files, created and named according to the Input File instructions for a Staging Table and Maintenance Object .
The process is multi-threaded and optimized for the parallel load.
Using the batch parameters you can control:
Level of logging
Data extract retention
Resume the interrupted load
Maximum number of load errors
