How To Adjust An Installment Plan Service Agreement
If you need to adjust the debt on a service agreement that's used to bill a total amount in installments, you have to ask yourself why you're adjusting the balance:
  • If you're adjusting the balance to correct the payoff balance (for whatever reason), choose an adjustment type that just affects this balance.
  • If you're adjusting the balance to correct the current balance (for whatever reason), choose an adjustment type that just affects this balance.
If you need to adjust both balances equally, choose an adjustment type that affects both.
