Contract Option - Main
Open Menu > Customer Information > Contract Option > Search to maintain contract options data.
This page is only available if the Complex Billing module is not turned off.
Description of Page
The Contract Option Info displays important information about the contract option. The Contract Option ID is a system-assigned random number.
Indicate the Contract Option Type for this contract option along with a Description.
If this contract option is linked to only one service agreement, indicate the Create For SA ID.
The characteristic collection is used to indicate additional information related to your contract option.
You can only choose characteristic types defined as permissible on the contract option record. Refer to Setting Up Characteristic Types & Their Values for more information.
To modify a characteristic, move to a field and change its value. To add a new characteristic, click + to insert a row then fill in the information for each field. The following fields display:
Effective Date Define the date on which the characteristic becomes effective.
Characteristic Type Indicate the type of characteristic.
Characteristic Value Indicate the value of the characteristic.
