TOU Data Query
This query shows the most recent interval data for a classic TOU Map and a time period as of a given time.
Open Menu > Interval Billing > TOU Data Query to display TOU map data.
This page is only available if the Complex Billing module is not turned off.
Description of Page
The TOU Map ID is the identifier of the TOU map whose data should be displayed.
Use the Start Date/Time and End Date/Time if you want to limit the query to a specific time period.
Use the Set Date/Time to indicate the "as of what date" to use for retrieving interval data. Only data sets with a set date/time prior to this date/time will be accessed.
The Selection Type is used to determine what data to show:
History This option displays all TOU map data for the classic TOU map and time period, if specified. It includes data in data sets of any status value.
Most Recent Comp. Exc. No Data This option finds the most recent interval value for each interval from completed data sets only. If the most recent interval is in a No Data data set, that interval does not appear.
Most Recent Complete Data This finds the most recent interval value for each interval from completed data sets only. If the most recent interval is in a No Data data set, that interval appears with "No Data" displayed in the Data Set Type column.
Fastpath:
Refer to Fixing Errors with Complete Data for more information about No Data data sets.
Once you have selected your criteria, use the search button to display the data. The TOU map data collection contains the following information:
The TOU Data Date/Time and Time of Use code for each interval is displayed. Information about the data set to which this interval is linked is displayed, including the Data Set Type, Set Date/Time and TOU Data Set ID.
If seasonal time shift records are linked to both the base time zone and the classic TOU map type, the Seasonal Time Shift associated with your classic TOU map type is displayed.
If seasonal time shift records are linked to both the base time zone and the classic TOU map type, the Seasonal Time Shift Remark indicates whether the data is displayed and should be entered in legal time or standard time. Refer to Interval Time Display for more information. If the data is displayed in legal time use the Show in Standard button to toggle to standard time. If the data is displayed in standard time use the Show in Legal button to toggle to legal time. If either the classic TOU map type or the base time zone do not indicate a seasonal time shift record, the toggle button is not visible and data is displayed and expected in standard time.
