Workflow Event Exception
As described in Workflow Events May Be In Error, a record is written the workflow event exception record for every workflow event record that is in error.
To view the messages associated with the exception records, schedule the TD-WEXTL background process. This process generates a To Do entry for every record in the workflow event exception table.
After correcting the cause of the error, drill into the Workflow Process - Events tab and change the status from Error to Pending. The next time the event activation process runs, it attempts to process this record again.
