Delete Button
Not all transactions have the capability to be deleted. Deletion is related to the business impact of the action. In some transactions, Delete is present for some scenarios and unavailable for others; for example, you may not be able to delete a record at a certain status level.
If you make a change to an object and do not save the changes to the database, you cannot delete the object until you either save the changes or refresh the object with the contents on the database.
Before you delete an object, the system verifies that the object is not referenced anywhere in the system. If it is, you cannot delete it. If, for example, you attempt to delete a user, the system ensures this user has not been referenced in a user group or on a To Do.
Depending on the type of page that you are using, the option to delete may vary.
  • Fixed pages display a Delete button in the page actions toolbar when the option is available.
    The Delete Button in the Page Action Toolbar
  • Portal-based pages display the Delete button in the object-related map.
    The Delete Button appears under the Record Actions section.
  • List style fixed pages commonly display the Delete button (garbage can icon) next to the entity in the list.
    The delete icon in the List Zone is located to the left of the Phone Type column.
In all cases, before the object is deleted, a confirmation dialog is displayed.
CAUTION: A timeout situation could occur as the system attempts to verify the use of the deleted object if the object is referenced in many places and involves large volumes of production data. If this timeout situation occurs, you must with your database administration group to delete the offending object.
