Text Box
The following is an example of a basic text box:
Description text box empty field.
If the text box is a large field, the text box may be configured to enable scrolling. In this situation, an expanded edit icon, (a pencil), will appear adjacent to it.
Text box with a vertical scroll bar.
Additional capabilities are provided to display and edit data in these text boxes:
  • If the field contains more text than is visible, a pop-up that displays the full text appears when you hover your mouse over the text box. The text in the pop-up can be selected and copied.
Text box with scroll bar.
  • If you click the expanded edit icon, an editable pop-up window appears. If the field is not protected as a result of business rules for the page, you may modify the text in this window.
Empty text Box in Edit data window.
Note: The following table highlights special characters that are converted to equivalent standard characters when entered in a text box.
Entered Character Description Unicode Converted Character Description
Curly left double quote.
U+201D
Straight double quote.
Curly right double quote.
U+201C
Curly left single quote.
U+2019
Straight single quote.
Curly right single quote.
U+2018
En dash.
U+2013
Simple hyphen.
Em dash.
U+2014
Simple hyphen.
Ellipse
U+2026
Three dots.
Middle dot (bullet / centered dot)
U+00B7
Asterisk.
Fraction 1/4 (using 1 character).
U+00BC
1/4 (using three separate characters).
Fraction 1/2 (using 1 character).
U+00BD
1/2 (using three separate characters).
Fraction 3/4 (using 1 character).
U+00BE
3/4 (using three separate characters).
