Designing Your Bill Segment Types
Example Service Agreement Types
The following table contains a subset of the SA types listed under Defining Service Agreement Types and Designing Your SA Types And Start Options For Sub SAs and Designing SA Types For Service Provider Financial Settlements. However, if you are reading this document from top to bottom, you probably don't know what your SA types are (they are only designed much later) and will have to forestall this task until that time.
We're going to cheat and assume you know what your SA types are and fill in the algorithms necessary to create bill segments for each SA type. After this table is complete, we will look for unique combinations of the 4 algorithms and create a bill segment type for each one.
Before you can fill in the columns for your own SA types, you should be comfortable with the descriptions of the algorithms described under Setting Up Bill Segment Types.
Div. SA Type |
Calculation Algorithm |
FT Algorithm |
Consumption Algorithm |
Auto Cancel Algorithm |
CA/G-RES |
Apply Rate |
Payoff = Bill Amount / Current = Amount Due |
Get Consumption from SPs |
Auto Cancel Bad Estimates |
CA/G-COM |
Apply Rate |
NA - can’t estimate consumption. |
CA/G-IND |
Apply Rate |
CA/CABLE |
Apply Rate |
CA/E-COY |
Apply Rate |
Payoff = 0 / Current = 0 |
CA/E-RESU |
Apply Rate To Usage Request |
Get Consumption Using Usage Request |
CA/E-COMU |
CA/WO-STD |
N/A - non billable |
CA/WO-LIA |
CA/CHARITY |
Recurring Charge |
Payoff = 0 / Current = Bill Amount |
N/A - no consumption is needed |
CA/PA-REGU |
Recurring Charge With Auto Stop |
CA/MERCH-I |
Recurring Charge For Amount To Bill |
CA/DEP-I |
CA/ONETIME |
Billable Charge |
CA/OVR UNDR |
CA/E-SUB ENR |
Apply Rate |
CA/E-SUB BC |
Billable Charge |
CA/E-FIN SETTL |
Algorithm Combinations
Now, we’ll extract unique combinations of the four algorithms and create a bill segment type for each.
Bill Segment Type |
FT Algorithm |
BD RATED |
BILLCHRG |
Billable Charge |
COMPUSAG |
RECUR |
Recurring Charge |
RECUR AS |
RECURATB |
SUB RATE |
Apply Rate |
Get Consumption From Master Bill Segment |
N/A - rated sub service agreements are cancelled when their master is canceled. |
SUB BC |
Billable Charge |
Sample Service Agreement Types and Bill Segment Types
Just to make sure everything has been designed appropriately, we will return to our SA type samples and specify their respective bill segment types:
Div. SA Type |
FT Algorithm |
Bill Segment Type |
CA/G-RES |
Apply Rate |
SP-RATED |
CA/G-COM |
Apply Rate |
NOESTRAT |
CA/E-RES |
BD RATED |
CA/E-COM |
BD RATED |
CA/G-IND |
Apply Rate |
NOESTRAT |
CA/CABLE |
Apply Rate |
SP-RATED |
CA/E-COY |
Apply Rate |
N/A - no consumption is needed. |
COMPUSAG |
CA/WO-STD |
CA/WO-LIA |
CA/CHARITY |
Recurring Charge |
RECUR |
CA/PA-REGU |
RECUR-AS |
CA/MERCH-I |
RECUR-AS |
CA/DEP-I |
RECURATB |
CA/ONETIME |
Billable Charge |
BILLCHRG |
CA/OVR UNDR |
CA/E-SUB ENR |
Apply Rate |
SUB RATE |
CA/E-SUB BC |
Billable Charge |
SUB BC |
CA/E-FIN SETTL |
And now you’re ready to set up your bill segment types.
