Distribution Rule - Algorithms
Navigate to and navigate to the Algorithms page to set up the algorithms appropriate for your distribution rule.
Description of Page
The Algorithms grid contains algorithms that control important functions. You must define the following for each algorithm:
- Specify the algorithm's System Event (see the following table for a description of all possible events).
- Specify the Algorithm to be executed when the System Event executes. Set the Sequence to 10 unless you have a System Event that has multiple Algorithms. In this case, you need to tell the system the Sequence in which they should execute.
The following table describes each System Event (note, all system event's are optional and you can define an unlimited number of algorithms for each event).
| System Event | Optional / Required | Description |
| Create Payment | Optional | This algorithm is executed to distribute a payment distribution detail payment amount into one or more payments. |
| Determine Tender Account | Optional | This algorithm is executed to determine the tender account associated with the payment distribution detail. Only one such algorithm may be specified. |
