Outgoing Validate Meter / Item Message
The service provided with the product that processes the Validate Meter / Item notification download staging record does the work of validating the badge number. The service, called CIPOVRSP, does the following:
  • Finds a unique device (meter or item) corresponding to the badge number provided.
The validation is only possible if the badge number is unique for a meter or item. If multiple values are found, a negative acknowledgement is returned.
  • Verifies that the device is not retired
  • Verifies that the Meter type or Item type of the device being verified is defined as valid for the SP Type associated with the field activity's service point.
  • It verifies that the device is not already installed somewhere else.
  • If the device is a meter, it verifies that there is an effective Meter Configuration for the meter on or before the message date/time.
Return Meter Configuration Type. The meter configuration type and the collection of the meter's registers are included in the output record returned to Oracle Utilities Mobile Workforce Management/Oracle Utilities Work and Asset Management.
  • If the device is an item, it verifies that the item's receive date is on or before the message date.
The system provides an XAI Inbound Service, ValidateMeterItemResponse, defined to invoke this service. The following table lists the fields populated by this service.
General Information
Message ID
FA ID
FA External ID
Meter / Item Flag (M or I)
Badge Number
StatusFlag (Y - positive acknowledgement, F - negative acknowledgement.)
Meter Config Type (populated only for meters)
Collection of registers (populated only for meters)
ErrorCode (populated only for negative acknowledgement)
Error Message (populated only for negative acknowledgement)
