Start Option - TOU Contract Value
Refer to Designing Your SA Interval Billing Options for information about setting up start options for interval service agreements.
This tab may not appear. This tab is suppressed if the interval billing Complex Billing module is turned off.
Open TOU Contract Value page to define the start option's default TOU contract values.
and navigate to theDescription of Page
The TOU Contract Value scroll contains information to define when you would like TOU contract values to be defaulted onto service agreements created using this start option
Indicate the Bill Factor associated with the TOU contract values. You may only reference bill factors designated as "TOU" bill factor types and where the value may be in contract terms.
Indicate the TOU Group, which contains the appropriate collection of TOU codes for service agreements created using this start option.
Indicate the Number of Days the value should be in effect. This value is used by the system to set the stop date on the service agreement's contract value. If the value has no expiration, set this field to 0.
Use the Time of Use collection to indicate the TOU Value associated with each Time of Use codes for the TOU Group.
For more information about TOU contract values, refer to Customer Specific TOU Values.
