Setting Up Market Provider Configuration Options
This portal is used to maintain Market Provider Configuration Options.
You can access the portal from Admin > Open Market > Market Provider Configuration Option. You are brought to a query portal with options for searching for a specific Market Provider Configuration Option. Once a record is selected, you are brought to the maintenance portal to view and maintain the selected record.
The following zones may appear as part of the portal's Main page:
  • Market Provider Configuration Option zone shows the details of the Market Provider Configuration Option.
  • Service Provider Market Options zone shows the service providers with their start dates, end dates (if applicable) and statuses. Maintenance actions are provided. A broadcast icon appears if the Service Provider Market Option has sub-SA(s) and/or entries in the Status History log. Clicking on the broadcast icon displays the following zones:
    • Service Agreements zone shows the Service Provider Market Option’s sub-SAs.
    • Status History zone shows the history of changes to the Service Provider Market Option, which can include changes to Start Date, End Date and/or Status.
