Designing Interval Billing Options
Your interval billing options control how interval data may be maintained and billed for your customers with this capability.
Fastpath:
For more information about interval billing, see The Big Picture Of Interval Billing.
Warning:
There are many ways to design your interval billing options. The flexibility of the system may add to the challenge of determining the best way to set up your control tables. In this section, we provide information to help you understand the ramifications of the various options. Before you set up your production data, we encourage you to gain an intuitive understanding of these options by using the system to prototype the alternatives.
The design of your interval billing options is an iterative process. Over time, you will develop intuitive skills that will allow you to skip some iterations. We recommend using the various steps in this section as a guide. When you are finished with this guide, you will be able to set up your interval billing options.
