SA Used for Miscellaneous Transactions
For some memberships, you may need to define a special service agreement to use for miscellaneous transactions. For example:
If events created for a membership cause an adjustment to be created to affect the general ledger, rather than allowing the system to arbitrarily pick a service agreement to use for this adjustment, the SA to use should be indicated on the membership. Refer to An Event May Cause Other Actions to Occur for more information.
