Designing Workflow Event Types
If we extract each unique event type from the above table, we end up with the following:
Workflow Event Type |
Validate notification - consumption history request |
Confirm requester is a valid service provider for the customer's service |
Create notification download - send consumption history |
Validate notification - supplier switch |
Current supplier confirmation |
Switch supplier |
Validate notification - interval meter switch |
Create field activity to exchange meter |
Change rate |
Create notification download - reject request |
Next, we have to determine the algorithm that will be used when each event is activated on its trigger date. We call this algorithm the activation algorithm. An activation algorithm is a stand-alone routine that does whatever you need done when an event is activated. We have populated the following table with brief descriptions of the types of activation algorithms you'd need for the above workflow events.
The activation algorithms are limited by your imagination (and business requirements). We have provided the activation algorithms you see below as an example; we don't expect you'll be able to use the exact algorithms that we supply. Your algorithms will be based on any number of factors. Be aware that new activation algorithms may require programming. See How To Add A New Algorithm for more information.
Activation Algorithm |
Validate consumption history request |
Confirm service provider is valid requester |
Validate supplier switch request |
Create notification download - check if it's OK to switch customer from current supplier |
Switch supplier |
Switch supplier |
Validate interval meter switch request |
Create field activity - exchange meter |
Change rate |
Change rate |
Next, we have to determine which types of events can fail. Refer to Some Workflow Events May Fail for background information failure. For those types of events that can fail, we will indicate their failure algorithm in the table. A failure algorithm is a stand-alone routine that does whatever you need none when an event fails. We have populated the following table with brief descriptions of the types of failure algorithms you'd need for the above workflow events.
The failure algorithms are limited by your imagination (and business requirements). We have provided the failure algorithms you see below as an example; we don't expect you'll be able to use the exact algorithms that we supply. Your algorithms will be based on any number of factors. Be aware that new failure algorithms may require programming. See How To Add A New Algorithm for more information.
Failure Algorithm |
Create notification download - invalid request |
Create notification download - invalid requester |
N/A |
Create notification download - reject request due to supplier rejection |
Switch supplier |
Switch supplier |
N/A |
N/A |
Change rate |
Change rate |
N/A |
N/A |
And finally, for those events whose activation algorithm puts them into a wait state, we have to determine the waiting process that monitors the waiting events. Refer to Waiting Events And Their Waiting Process for more information about waiting.
The waiting processes are limited by your imagination (and business requirements). We have provided the waiting processes you see below as an example; you may not be able to use the exact processes that we supply as your processes will be based on any number of factors. Be aware that a new waiting process will require programming.
Failure Algorithm |
Waiting Process |
N/A |
N/A |
N/A |
N/A |
N/A |
Check if supplier has accepted process |
Switch supplier |
Switch supplier |
N/A |
N/A |
N/A |
N/A |
Check if field activity is complete |
Change rate |
Change rate |
N/A |
N/A |
N/A |
N/A |
