Setting Up Notification Upload Types
Every notification upload staging record has a notification upload type. This code is one of several fields that control the type of workflow process used to process the incoming notification. Open
to define your notification upload types.Refer to Designing Notification Upload Types f or more information.
Description of Page
Enter a recognizable Notification Upload Type and Description.
Enter a value for the Upload Condition Flag when a system condition should trigger the creation of a notification record. Refer to System Conditions May Trigger Notification and Workflow for more information.
The values for this field are customizable using the Lookup table. This field name is NT_UP_TY_COND_FLG.
If NUS records of this type will be associated with an Extension record, indicate the extension here along with its Navigation Option to allow a user to navigate to the correct extension record when viewing the notification upload staging record. Refer to Navigating to Related NUS Extension for more information.
Where Used
A Notification Upload Staging record must reference a notification upload type.
A Workflow Process Profile references one or more notification upload types.
