Umbrella Agreement Type - Algorithms
Open Admin > Umbrella Agreement > Umbrella Agreement Type > Search and navigate to the Algorithms page.
Description of Page
The grid contains Algorithms that control important functions in the system. You must define the following for each algorithm:
  • Specify the System Event with which the algorithm is associated (descriptions of all possible events are provided below).
  • Specify the Sequence and Algorithm for each system event. You can set the Sequence to 10 unless you have a System Event that has multiple Algorithms. In this case, you need to tell the system the Sequence in which they should execute.
The following table describes each System Event for which you can define algorithms.
System Event
Description
UA Renewal
Algorithms of this type are executed by the UARENEW background process when an umbrella agreement has reached its renewal date.
Only one renewal algorithm is allowed for a given UA type.
