Meter Reads Performance - CI_MTREAD
Parameters
Parameter |
Parameter Code |
Description |
Accounting Period |
P_ACCT_PERIOD |
Defines the accounting period used for the report. A valid fiscal year and accounting period for a valid accounting calendar must be provided. |
Report Description
This report selects bill segments for the input accounting period and displays the total number of read meters and unread meters for these bill segments grouped by route type.
Meters that are considered read are meters whose register reads have a status of Regular or Verified . Meters that are considered unread are meters whose register reads have a status of System Estimate, Office Estimate, System Prorate or Billing Force.
Performance Consideration. If your implementation chooses to use this report, you may consider adding an index to the CI_FT table on ACCOUNTING_DT to aid in performance. When making this decision, carefully weigh the benefit of improving report performance against the possible degradation to the performance of day-to-day processing as a result of defining a new index. In addition, many companies opt to create a reporting database that is a shadow of production to ensure that indexes defined to benefit reports may be created without any affect on the production environment.
