Read History
This page shows the history of a register's reads. Open this page using
Description of Page
Register ID identifies the register whose reads are shown in the grid.
Filter by controls the reads that appear in the grid:
- If you want to restrict the history to reads that are eligible to appear on a bill, choose Billable Reads Only. This is the default value.
- If you want to see all reads linked to the register, choose All .
- If you want to restrict the history to reads that are NOT eligible to appear on a bill, choose Non-Billable Reads Only.
The remaining points describe the columns in the grid.
Read Date/Time is the date and time of the meter read.
The Read Difference column shows the difference between this read and the previous read.
The Message column highlights the following:
- The resultant usage. For subtractive registers, this is the difference between this read and the prior read. For consumptive registers, this is the register reading.
- The valid usage. This is the range of usage that won't trigger a high / low failure. These values are not shown if the read was not subject to high / low checks when it was added.
- The valid readings. This is the range of readings that won't trigger a high / low failure. These values are not shown if the read was not subject to high / low checks when it was added. Note, these values are only calculated for subtractive registers as the valid usage is the same as the valid readings for consumptive registers.
The Message column is red for those readings that have failed high / low checks.
The High/Low Failed column is checked if the read was not within the boundaries of the estimated high and low read values calculated by the system at the time the read was validated.
Refer to Meter Read - Main for the definition of all other columns.
