Billable Charge Line Characteristic Upload Staging Layout
If you want to upload characteristics on your billable charge lines, you must create a billable charge line characteristic upload record for each characteristic on each line. The name of this table is CI_B_LN_UP_CHAR. The following table describes each column on this table.
 Column Name  |
 Length  |
 Req'd  |
 Data Type  |
 Comments  |
 BCHG_UP_ID  |
 30  |
 Y  |
 Char  |
 This is the foreign key to the billable charge upload staging record.  |
 LINE_SEQ  |
 3  |
 Y  |
 N  |
 This is the foreign key to the billable charge line upload staging record  |
 CHAR_TYPE_CD  |
 8  |
 Y  |
 Char  |
 This is the unique identifier of the billable charge line characteristics. This value must be unique within the billable charge line characteristics.  |
 ADHOC_CHAR_VAL  |
 30  |
 N  |
 Varchar2  |
 An ad hoc characteristic value must be supplied if the ad hoc switch on characteristic type is Y. Otherwise, it is not allowed.  |
 CHAR_VAL  |
 16  |
 N  |
 Char  |
 A characteristic value must be supplied if the ad hoc switch on characteristic type is N. Otherwise, it is not allowed.  |
 CHAR_VAL_FK1  |
 50  |
 N  |
 Varchar2  |
 A characteristic value foreign key must be supplied if the ad hoc switch on characteristic type is Y. Otherwise, it is not allowed.  |
 CHAR_VAL_FK2  |
 50  |
 N  |
 Varchar2  |
 CHAR_VAL_FK3  |
 50  |
 N  |
 Varchar2  |
 CHAR_VAL_FK4  |
 50  |
 N  |
 Varchar2  |
 CHAR_VAL_FK5  |
 50  |
 N  |
 Varchar2  |
