Package - Instructions
This page is used to define special instructions that should be presented to the user when they select this package. This information appears on the Order - Package Confirmation page.
Fastpath:
Refer to Determine If Additional Instructions Are Needed for more information.
Open this page using Menu > Sales & Marketing > Package > Search and navigate to the Instructions page.
Description of Page
Package contains a concatenation of basic information about the package. Package ID is the system-assigned unique identifier of the package. These values only appear after the order is added to the database.
The grid contains a row for each instruction to be presented to the user when they select a package. The following fields are used:
  • Use Sort Sequence to control the relative order of the instruction.
  • Use Display Icon to control the icon that prefixes the instruction. Refer to Display Icons for more information.
  • Use Description to define the text of the instruction.
