Hours-Based Electric Rate
Warning:
If your organization does not sell electric service (or if you do and don't use hour-based steps) you might want to skip this example as it involves understanding a fairly complex electric concept - kWh / kw = hours.
The following table illustrates the rate components necessary to levy a rate that contains the following charges:
  • Monthly service charge: $10.00.
  • First 10 hours of use at $0.0673 per kWh.
  • Remaining hours of use at $0.032 per kWh.
  • State Tax at the prevailing rate (this tax is a percentage of a dollar value).
  • County Use Tax at the prevailing rate (this tax is an amount per kilowatt-hour).
Seq #
RC Type
Value Type
Value
Bill Factor
Item
Type
UOM/TOU/SQI
Step Range
Cross Reference
Calc Only
Result Type
10
Flat Charge
Charge
10.00
N
20
Service Quantity
Unit Rate
1.0
KW
Y
Unit Rate
30
Service Quantity
Unit Rate
0.0673
KWH
0 to 10 Multiply by RC: 20
N
40
Service Quantity
Unit Rate
0.032
KWH
10 to 99999999 Multiply by RC: 20
N
50
Summary
30, 40
N
60
Apply To
Percent
STTAX
10, 30, 40
N
70
Apply To
Unit Rate
COUNTYTAX
30, 40
N
