System Override Date
The system provides a way to override the system date used for online operations. This feature is available if the server administrator has enabled it in the environment properties. For instructions on configuring environment properties see the Server Administration Guide. The system date override feature is not recommended for production environments.
Under the General System Configuration Feature Configuration, the System Override Date Option Type holds the date the application will use as the global system date instead of retrieving the same from the database. This feature can be especially useful in running tests that require the system date to be progressed over a period of time.
The system override date feature is also available at the user level. This is useful when a user wants override the system date to run tests without affecting the system date for other users in the environment. In order to override the system date for the user, open the User — Characteristics page, add theSystem Override Date characteristic type with a characteristic value set to the desired date in the YYYY-MM-DD format.
If system override dates are defined at both the feature configuration level and the user level, the date set at the user level will take precedence.
