Editing Export Bundles
You can add or remove entities from an export bundle when it is in Pending state. You can also change the sequence of entities.
To edit to an export bundle that has already been bundled, you must change the bundle state by selecting the Back to Pending button on the Bundle Export portal.
- Open the bundle in edit mode.
- Click Edit on the Export Bundle portal.
- Make any necessary changes on the edit dialog and then click Save.
