User Redirection
The product allows an implementation to support the ability for a customer to authorize a customer service representative (CSR) to view the customer's account information in a customer facing portal (Digital Self Service), to see exactly what the end customer is seeing/experiencing.
When the request for the CSR to view the customer information is received, the following steps occur:
  • The security server for the customer facing portal is contacted to obtain a temporary grant code.
  • The redirection response returns the grant code and the URL of the target customer facing portal.
  • The browser redirects to the user to this URL with the grant code, which is further authenticated and automatically exchanged for an authorization token, allowing the CSR to log in.
Standard security measures with private/public key encryption using JSON Web Tokens (JWT) ensures that only the implementation's enterprise application is allowed to communicate with the implementation's customer facing portal server.  The system also provides a plug-in spot to allow for additional information, such as the customer's name and email address, to be included in the call to the security server.
This feature works in conjunction with functionality provided by the enterprise customer application.  Refer to the documentation for that product for information about how this feature is supported.
Note: The product has been designed to potentially support other types of redirection besides the mentioned use case by adding another entry in the Redirection Target lookup (F1_​REDIRECTION_​TARGET_​FLG). However, the internally provided services work specifically for the Digital Self Service use case. There is no guarantee that they would work for a different redirection use case. Please contact product support if your implementation would like to implement a different redirection scenario.
Redirection Security Context Plug-in
The product supports a plug-in spot to allow for the system to populate additional keys and values to add to the JWT (JSON Web Token) when calling the external security service.
In addition, the product provides an Extendable Lookup BO Redirection Security Context (F1-RedirectionSecurityContext) to define the key mnemonic values. For an enterprise product or implementation to populate additional keys, use the extendable lookup to define the key mnemonics. Then provide an algorithm that uses the available information about the customer and populates the security context keys and values by determining the related data in the system.
Master Configuration
The master configuration Redirection Targets Configuration (F1-RedirectionTargetsConfig) defines the information needed to contact the security server to obtain a grant code. It also defines the redirection URL.
