Override Maps - SA Characteristic
The classic TOU map creation algorithm needs to know the correct classic TOU map template to use to generate TOU data when the interruption occurs. Our algorithm assumes that the classic TOU map template is defined as a characteristic on the service agreement.
Create a foreign key reference for the classic TOU map template.
Create a new Char type with the following attributes:
- Type is FK Reference
 - FK reference code is the one created above for classic TOU map template
 - Char Entity is Service Agreement
