User Interface
The base product allows for the conditional inclusion of custom style sheets into the system style set. Custom styles may override any style provided by the base product. The style sheet may also include new styles for use in customer zone definitions. Use the Style Sheet option on the Custom Look And Feel Feature Configuration to define your custom style sheet.
Note: Some styles cannot change if they are part of the HTML code.
CAUTION: Implementers must ensure that the customized
user interface is stable and scalable. Changing font, alignment padding,
border size, and other user interface parameters may cause presentation
problems, like scrollbars appearing or disappearing, cursors not working
as expected, and unanticipated look and feel alterations of some layouts.
