Editing Import Bundles
You can remove entities from an import when it is in Pending state. You can also change the sequence of entities and edit the generated XML.
- Open the bundle in edit mode.
To edit the XML snapshot, click Edit XML. Edit the XML code as needed, then click Save.
Note: Use caution when editing the XML to avoid validation errors.
- To remove entities or change their sequence, click Edit. Make any necessary changes and click Save.
