UI Map - Main
Use this page to define basic information about a user interface (UI) Map. Open this page using
Use the UI Map Query portal to search for an existing UI Map. Once a map is selected, you are brought to the maintenance portal to view and maintain the selected record.
Description of Page
Enter a unique Map name. Owner indicates if the UI map is owned by the base package or by your implementation (Customer Modification).
Use UI Map Type to indicate the map type. The system recommends using a Complete XHTML Document (the default) or XHTML Fragment. The values Complete HTML Document and HTML Fragment remain for backward compatibility but are not recommended.
Enter a Description. Use the Detailed Description to describe how this map is used in detail.
Click on the View Schema to view the UI map's expanded schema definition. Doing this opens the schema viewer window.
Use the Test UI Map hyperlink to render your HTML in a test window.
