SQL Loader Control Files
The control files are for internal use and are generated for each of the conversion tables that are supported by the product. These files are used by SQL Loader to interpret and load the data that is provided in the conversion data files.
The control file contains:
General load parameters and options
Data field specifications and table-specific load instructions
For more details refer to Conversion Artifact Generator .
