Identity and Access Management Integration Configuration
The Identity and Access Management Integration Configuration master configuration stores the definitions related to the integration with Oracle Cloud Infrastructure Identity and Access Management.
For Just-In-Time User Provisioning, configure the User Provision Rules:
  • Map the Groups defined in the identity domain to the Template Users defined in the application.
