Budget Plan - Calculation Algorithm
On Budget Plan - Main you must define the Calculation Algorithm used by the system when it calculates a customer's recommended budget amount.
If you haven't done so already, you must set up this algorithm in the system. To do this:
- Create a new algorithm (refer to Setting Up Algorithms ).
 - On this algorithm, reference an Algorithm Type that calculates recommended budget amounts.
