Meter - Characteristics
The characteristics page contains information that describes miscellaneous information about the meter. Use and navigate to the Characteristics page.
Description of Page
Meter Info is a concatenation of the meter's meter type and badge number.
Meter ID is the system-assigned random number that stays with a meter for life. This value only appears after the item exists on the database.
To modify a characteristic, simply move to a field and change its value. To add a new characteristic, click the + button to insert a row, then fill in the information for each field. The following fields display:
Effective Date Indicate the date on which the characteristic value becomes effective. The meter's date received defaults.
Characteristic Type Indicate the type of characteristic.
Characteristic Value Indicate the value of the characteristic.
Default note. If the meter's meter type has required characteristics, the respective characteristic types will default in the above grid.
