Message Option
The Message Option page defines various system settings used by the system when processing external messages.
To define options for your environment, open .
Description of Page
The following options are supported.
| Option | Description | Option Name |
| Default Email Sender | This is the default Message Sender used for sending e-mails when no explicit Message Sender is specified. | defaultEmailSender |
| Default User | The default user is used by the system to access your product when no other user is explicitly specified. | defaultUser |
| Email Attachment File Location | This is the default location of e-mail attachment files. If not specified, the e-mail service provided with the product assumes a full path is provided with each attachment file. | emailAttachmentFileLocation |
| Email XSL File Location | This is the default location of e-mail XSL files. If not specified, the e-mail service provided with the product assumes a full path is provided to an XSL file as part of an e-mail request. | emailXSLFileLocation |
| Messages Language | The default language to use for the messages. | language |
| Outbound Message Schema Location | Enter the full path of the virtual directory where valid W3C schemas are stored if your implementation wants to validate outbound message schemas. For example: http:/localhost/cisxai/schemas. | xaiOuboundSchemaLoc |
| Schema Validation Flag | Enter Y to turn on schema validation for outbound messages. Enter N to turn this off. | xaiSchemaValidationCheck |
Note that the following options are no longer applicable.
| Option |
| To Do Type for Inbound JMS Message Errors |
| To Do Type for Outbound Message Errors |
| XSD Compliance |
