Understanding Information Lifecycle Management (ILM)
Information Lifecycle Management (ILM) is a separately licensable component of Oracle Utilities Customer Care & Billing that works in tandem with the Oracle database feature of the same name.
For general information about the ILM process and how ILM works with OUAF applications, refer to the Information Lifecycle Management chapter of the Oracle Utilities Application Framework Administrative User Guide.
This section provides an overview of the components used by the Information Lifecycle Management functionality.
ILM-Enabled Maintenance Objects: Retention Period
The majority of Maintenance Objects support a single retention period. They can either inherit the system-wide retention days that are configured on the ILM Configuration master configuration or they can have a retention period specified via the Maintenance Object option ILM Retention Period in Days.
CCB ILM-Enabled MOs
The CCB MOs support only a single retention period and many CCB MOs do not support the BO level setting.
ILM Eligibility Algorithm Type: The algorithm type description contains and specific consideration that are considered when determining if the record is eligible for ILM. Please review the algorithm type for the details including object cascading.
Restrict By Status: If the framework ILM eligibility algorithm (F1-ILMELIG) is used, the restricted status as delivered with the system are shown.
Maintenance Object |
ILM Eligibility Algorithm Type |
Restrict By Status |
Adjustment |
C1-ADJILMELG |
N/A |
Bill |
C1-ILMELG-BL |
N/A |
Bill Segment |
C1-ILMELG-BS |
N/A |
Billable Charge |
F1-ILMELIG |
Yes. Status: Canceled |
Case |
F1-ILMELIG |
Yes. Status: Closed |
Customer Contact |
C1-CCILMELIG |
N/A |
Customer Relationship Request |
F1-ILMELIG |
Yes. BO final status. |
Customer Service Request |
C1-CSILMELG |
N/A |
Customer Service Request Person |
F1-ILMELIG |
Customer Service Request Account |
F1-ILMELIG |
Customer Service Request Premise |
F1-ILMELIG |
Customer Service Request SA |
F1-ILMELIG |
No |
Customer Service Request Service Location |
F1-ILMELIG |
CS Request Consumer Contract |
F1-ILMELIG |
Customer Service Request Contract Product |
F1-ILMELIG |
Field Activity |
F1-ILMELIG |
Yes. Statuses: Complete, Canceled |
Financial Transaction |
N/A. The eligibility criteria checks are directly in the crawler batch process algorithms. Refer to C1-FTCRL batch control in the application. |
N/A |
Market Charge |
F1-ILMELIG |
Market Payment |
F1-ILMELIG |
Market Usage |
F1-ILMELIG |
Match Event |
C1-MEVILMELG |
N/A |
Meter Read |
C1-ILMELG-MR |
N/A |
Order |
F1-ILMELIG |
Payment Arrangement Request |
F1-ILMELIG |
Payment Event |
C1-PEVILMELG |
N/A |
Response |
F1-ILMELIG |
No |
Usage |
F1-ILMELIG |
No |
Adjusting Eligibility of Non-Final Transactions
As delivered, Oracle Utilities Customer Care & Billing maintenance objects allow non-final transactions to be eligible for archive. This is a logical approach when transactional data has a very long retention period.
If non-final transactions should not be eligible for archive this can be controlled at either the Maintenance Object (MO) or Business Object (BO) level:
- MO - ILM Restrict By Status (Y/N): Setting this to "Y" opts into the ability to restrict archiving by status. This is required to be set for either of the MO or BO level restrictions to be considered. To enforce the status, it requires that either the ILM Restrict By BO Final Status (Y/N) option or ILM Final Status Field Value option is also configured.
- MO - ILM Restrict By BO Final Status (Y/N): Setting this to "Y" indicates that the transactions for the MO must be in a final status to be eligible for ILM. A status is considered to be final, based on the BO lifecycle configuration. This can be overridden by the BO option Final Status Required for Archive (Y/N). This is only applicable for an MO that is maintained by business objects.
- BO - Final Status Required for Archive (Y/N): Setting this to "Y" indicates the transactions for this particular BO must be in a final status. This setting overrides the MO level ILM Restrict By BO Final Status (Y/N).
The following table helps to illustrate how these three settings impact whether a given transaction must be in a final status:
Proactive Archive Eligibility for Transactional Data
Some types of transactional data can be analyzed for archive eligibility as they are received rather than waiting until their retention period has expired. This means that these records are judged ready to be archived as they are created and do not need to be read, analyzed, and updated during the ILM crawling process. This greatly reduces the number of records to be crawled at the end of the retention period and shortens the window of time required for ILM crawling. This approach exists in Oracle Utilities Meter Data Management and Oracle Utilities Customer to Meter. For more information, refer to the user documentation of these applications.
