Customer and Premise Data Extracts: Batch Controls
Customer Data
The customer data extraction process uses a set of batch processes to create data synchronization requests and extract files.
Current DataConnect -
Customer Data Initial Load for DataConnect (C1-CDTIL): This batch control creates initial synchronization requests for account data (service agreements/accounts/persons) and SA's SP data (SA/SP). The appropriate sync business objects for the two extracts should be plugged in as parameters to the batch job.
Mail Address Initial Load DataConnect (C1-MADIL): This batch control creates initial synchronization requests for accounts.
Legacy DataConnect -
SA-Based Initial Load for Legacy DataConnect (C1-SAEIL): This batch control creates initial synchronization requests for service agreements / accounts / persons.
SP Initial Load for Legacy DataConnect (D1-SPEIL): This batch control creates initial synchronization requests for service points.
Customer Data Extract for DataConnect (C1-CUDTX): This batch control creates extract file(s) for service agreements / accounts / persons related information.
SA/SP Data Extract for DataConnect (C1-SSDTX)
Mailing Address Extract DataConnect (C1-MADTX): This batch control creates extract file(s) that contain mailing address information.
SA-Based Extract for DataConnect (C1-CUDTX): This batch control creates extract file(s) for service agreements / accounts / persons related information.
SP Extract for Legacy DataConnect (D1-SPESR): This batch control creates extract file(s) that contain service point information.
These batch controls are defined as values for the Batch Control for Extract algorithm parameters on the Pre-Processing algorithms on the Sync for DataConnect business objects (see above).
Use the Batch Control portal for more information about these batch controls. The extract batch controls contain parameters that can be used to specify details (including path and file name for this file.) for a delimited flat file containing extracted data.
Premise Data
The premise data extraction process uses a set of batch processes to create data synchronization requests and extract files.
SP/Meter Initial Load for DataConnect (D1-SPMIL): This batch control creates initial synchronization requests for service points, device configurations, and devices.
Install Event Initial Load for Legacy DataConnect (D1-IEEIL): This batch control creates initial synchronization requests for install events.
SP/Meter Extract for DataConnect (D1-SPMSR): This batch control creates extract file(s) that contain service point, device configuration, and device information.
Install Event Extract for Legacy DataConnect (D1-IEESR): This batch control creates extract file(s) that contain install event information.
