Function - Main
Use this page to define basic information about a function. Open this page using
Description of Page
Enter a unique Function code and Description for the function.
Use the Long Description to describe, in detail, what the function does.
Define the Internal Service that the function invokes.
Note: Only page services can be invoked.
The tree summarizes the following:
- The fields sent to the service. You can use the hyperlink to transfer to the Send Fields tab with the corresponding field displayed.
- The fields received from the service. You can use the hyperlink to transfer to the Receive Fields tab with the corresponding field displayed.
- Scripts that reference the function. You can use the hyperlink to transfer to the script page.
