Maintaining Sync Requests
The system provides a Sync Request portal that is used to view the in progress or completed sync request records.
The menu location of the portal depends on your specific edge product. It may be in a Data Synchronization menu or perhaps in the Batch menu. You are brought to a query portal with options for searching. The options may differ based on your specific product.
Once a sync request has been selected, you are brought to the maintenance portal to view and maintain the selected record.
An Actions zone may appear to display specific actions. Alternatively, the actions may be displayed directly in the display area of the Sync Request zone.
The Sync Request zone provides basic information about the sync request record.
Depending on your specific product additional zones may appear.
