Assistant Area
The assistant area is a special area that may appear for your product, depending on what is offered.
The assistant area is located directly above the Sidebar Area and as such, is impacted by some of the appearance behavior that applies to the sidebar. If you collapse the sidebar area, the assistant area is also collapsed. If you adjust the sidebar width, the assistant area width is adjusted accordingly. However, the refresh events that impact the sidebar do not impact the assistant area.
Refer to your product's specific documentation for more information about the functionality visible in this area.
