Security Setup for Conversion
The services associated with data conversion are combined into the following user groups:
Conversion Administrators includes the services linked to the most sensitive database operations: enable/disable conversion and switching database synonyms between production and staging schema
Conversion Development includes the services associated with conversion-related configurations
Conversion Operations provides access to services associated with data load batch processes. This group could be extended to include services associated with specific table(s) or maintenance object data loads
These user groups are included in the base product. Your implementation may chose to use it as is or create a different setup.
