Defining DataConnect Options
Oracle Utilities DataConnect facilitates data extraction from Oracle Utilities applications such as Oracle Utilities Customer to Meter and Oracle Utilities Customer Care and Billing for use in external applications; such as, analytics applications and energy management systems.
This section describes how Oracle Utilities DataConnect works and how to implement and configure the system to support data extract processing.
There are two versions of DataConnect. The initial version is
referred to as “Legacy DataConnect”. The current and recommended version
is simply referred to as “DataConnect” or “Current DataConnect”. Implementations
are recommended to use the current version. “Legacy DataConnect” remains
available for implementations that used the initial version, but is
not recommended for new implementations.
