Device Test - Characteristics
The characteristics page contains device test results. Use and navigate to the Characteristics page.
Default note. When a device test is first created, all required characteristics will be defaulted (the operator need only specify their respective characteristic values).
Description of Page
The top portion of every page in this page contains the following information:
Device Test is a concatenation of summary information about this device test. It is composed the device's badge number, the test date, and the test's status.
Device Test ID is the unique system-generated identifier for this device test.
To modify a characteristic, simply move to a field and change its value. To add a new characteristic, click + to insert a row, then fill in the information for each field. The following fields display:
Characteristic Type Indicate the type of characteristic.
Sequence Controls the order in which characteristics of the same type are displayed.
Characteristic Value Indicate the value of the characteristic.
Where Used
The data on this page may be used during the execution of the device test's test type's validation algorithm. Refer to Device Test Validation for more information.
