Item Replicator - Item
The Item page is a display-only page provided to let you confirm that the item you selected is the one to be used as the template by the replicator. Use and navigate to the Item page.
Some equipment may not be copied. Equipment that is linked to the template item will NOT be replicated on the replicated items if the equipment references an item type that does NOT permit multiple equipment assignments. Refer to The Big Picture of Meters, Items and Equipment for more information about equipment linked to items.
Description of Page
This is a display-only page that displays information about the registers linked to the item identified in the add dialog. Refer to Item - Main Information for a description of the fields.
