Referencing URIs
There are some configuration objects that require a reference to a URI, including file path URIs. The following sections highlight some functionality supported by the product with respect to defining / accessing URIs.
In order for the functionality described below to occur, specific
APIs must be used by the underlying code related to the fields that
capture or process the file path or URL information. If you find that
there is a URI-related field that does not provide the functionality
described here, please contact customer support.
For schema elements in a business object that reference a Field with the URI data type or define the element with the URI data type configured in the schema will automatically use the appropriate
API that validates the value that may reference a substitution variable
or must be checked against the allowlist if applicable.
